Thread 370/52
Abrasive blasting to prepare aluminum for powder coating
I paint large sign structures and would like to switch from steel with solvent paints to aluminum structures and powder coat. I don't want to set up enormous dipping tanks or deal with the chemicals, can I use abrasive blasting as a surface preparation for aluminum and steel and powder coat immediately after blasting?
Tony Fischlisign manufacturer - Inverell, NSW, Australia
publicly reply to Tony Fischli
The enormous tanks and chemicals, to which you refer, are pretreatments that are required to get good adhesion and long life from painted aluminum.
If you are not ready to invest in the proper treatments, it is better to stay in steel and solvents. The best thing to do would be to find out the paybacks for switching. It may be worth it to switch to save money, and secure your future business, but there will be a learning curve, and and and investment.
publicly reply to Tom Pullizzi
Abrasive blasting of aluminum with media that has been used on steel will then imbed fine steel particles in the soft aluminum. As the media gets dirty you will be pounding organic trash into the soft aluminum also.
Call in you favorite cleaner salesman and buy a non-foaming combination cleaning and phosphating compound containing molybdenum salts. Apply this compound thru a steam cleaner
⇦ this on
Amazon [affil links]
or a hot water spray machine.
Rinse with a water hose. The run off from the steam cleaning apron may be neutralized with swimming pool soda ash (sodium carbonate
⇦ this on
Amazon]
), and put on the grass.
publicly reply to Robert H Probert
A. Hi. Robert may be correct that it is ecologically safe to put the neutralized waste on the grass. Further, it might be legal for a sign painter to do so (I don't know). But readers are cautioned that the EPA imposes "categorical" discharge standards on various industries; for example if you are an aluminum anodizing jobshop you most certainly are not allowed to do this because anodizing jobshops have categorical standards whereby all of their wastes are regulated.
publicly reply to Ted Mooney
