PROTECTIVE DIPPING WAX
LOOKING 4 SOME OF THAT WAX THAT You DIP END MILLS IN ONCE U'VE RE SHARPENED THEM.
thom waggener
- DURANT, Oklahoma
Thom, call Evans Manufacturing in Troy, MI [area code 248]. They make quite a variety of peel-coats used for temporary protection of tools, etc. McMaster-Carr also sells some of this stuff. Good luck from PlaterB
berl stein berl sig
"PlaterB" Berl Stein
NiCoForm, Inc.
Rochester, New York
nicoform
I notice you are in OK. I used to buy the same product as mentioned in the previous letter from a Midwest Supply right there in Tulsa. They kept a large stock on hand. That might work out better for you. Good luck.
Paul Norman
Paul Norman
- Odessa, Texas
