Thread 37/21
Precleaning procedure for powder coating
We are studying the installation for powder coating. Kindly advise necessary procedure (cleaning) prior to coating. The semifinished product is made of welded angle iron parts.
George Countas- Limassol, Cyprus
publicly reply to George Countas
Don't take it personally, Mr. Countas, but your letter is representative of half a dozen we received today that are overly broad. I hope you get some response, but in general a question which is too broad and would require several chapters in a book, tends to sit here unanswered. If you can narrow it so that it can be answered in a paragraph or two you will get much better response. Good luck. Regards.
publicly reply to Ted Mooney
George - Ted is right, being too broad in your question can sometimes bring disasterous (and sometimes ridiculous) recommendations. With that being said, I'm gonna give it a try anyway. A general pretreatment process for steel contains (but is not limited to):
1)alkaline wash
2)rinse
3)phosphate (iron or zinc)
4)rinse
5)finishing rinse(sometimes containing a sealer)
Hope this helps get the ball rolling. Good luck.
Dan Brewerchemical process supplier - Gurnee, Illinois
publicly reply to Dan Brewer
