Need to conventional anodize areas of hard coat anodized part
I have some parts that were hard coat black anodized. We later machined some small areas due to a design change. The reworked areas do not need to be hard coated, but should be black and anodized for corrosion reasons. Can the unprotected areas be black anodized with a conventional anodizing process without stripping the hard anodized areas?
Kerry Murphy- Lynchburg, Virginia
First of three simultaneous responses -- 2005
Kerry
You should be able to have the bare aluminum surfaces anodized, conventional or hard, and dyed black. If the original coating was sealed properly, you should get decent results. If not, you may have to buff the original surface after the second coating.
You'll need to specify whether or not to seal the second coating, based on the initial coating requirements.
- Colorado Springs, Colorado
Second of three simultaneous responses --
Check out letter 36552, it should answer most of your questions pretty well.
Jim GorsichCompton, California, USA
Third of three simultaneous responses --
YES, if you can make electrical contact. Clean in dishwashing compound, skip the etch, scrub with Scotchbrite, deox in the anodizing tank before turning on the power.
