What specification is 14-78-3-707 for paint
I have a requirement to have Paint with the specification;
14-78-3-707. I cannot find this spec anywhere and the only reference I have is that is supplied by Boeing Co, Seattle, WA. I would rather purchase it from a local supplier, rather then from Boeing. Could you please identify this spec paint as to what exactly it is, so I can purchase it local. Thanks.
Rgs,
Airline Industry - Melbourne, Vic, Australia
A. Hello!
I'm working on doing a revision to a Boeing manual right now (for a Retractable Landing Light) and saw your question.
I'll see if I can give you some of what I've got here, I had the same question when trying to correct the consumables list in this manual.
Part Number
14-78-3-707
CAGE Code
81205
THE BOEING COMPANY DIV DEFENSE SPACE & SECURITY DBA BOEING
Alternate/Reference Part Number
PA567 (Grimes)
Boeing Spec
BMS 10-60 Type II
Color #
BAC 707
Color
Gray
Finish
Gloss
Type
Polyurethane enamel - flexible
Air Dry
Yes
You may be using a manual right now that I'm applying the correction to. I'll make sure the Boeing Spec makes it into the list (since it doesn't look like it's there at the moment).
- Phoeniz, Arizona, USA
