Removing water spots on car finishes
My Dodge Ram Quad Cab pickup has numerous hard water spots on the finish, Can a solution of Muriatic acid and water remove these spots successfully?
Marty ScheeperReal Estate agent - Antelope, California
It will remove the hard water spots, but may remove the pickup as well. Muriatic acid is way, way, way, too strong a material to use for an application like that. If no commercial product works, vinegar ⇦in bulk on eBay or Amazon [affil links] and water will.
Forget the acids, get a good quality rubbing compound ⇦ this on eBay or Amazon [affil links] from your local auto specialty paint shop.
James Watts- Navarre, Florida
