Electroless copper plating and electroless nickel plating
A final year student carrying out project.
I want to find out if a non-cyanide copper electroless plating can be done on mild steel.
I also want to find out if electroless nickel plating can be done on mild steel.
project - OWERRI, IMO, NIGERIA
Yes, and yes. Electroless nickel is an autocatalytic plating bath where the presence of either steel or nickel causes additional nickel to deposit; my research-less guess would be that more electroless nickel is deposited on steel substrates than any other substrate.
Autocatalytic electroless copper is probably deposited on fiberglass printed circuit boards more than on steel, but it can be deposited onto steel. And immersion copper plating, where we simply rely on copper to deposit on steel by virtue of being more noble and coming out of solution preferentially, while of value only for limited applications, is nonetheless very common.
Q. Does Electroless copper plating have an advantage over electrolytic copper plating?
I carry out electrolyte copper plating, please help.
Engineer - Mumbai, Maharashtra, India
March 27, 2012
Hi Abhiraj.
I'm not personally aware of electroless (autocatalyltic) copper plating being used for any other purpose than metallizing plastics, especially printed circuit boards -- but maybe a reader can educate us both.
March 27, 2012
Hello Abhiraj,
As Ted said there are certain applications where ElectroLess Cu has to be used. It does have advantages in respect to what it can accomplish that Electrolytic Cu can't. ElectroLess Cu is not meant to be plated as a final finish because of thickness limitations and deposit characteristics. For instance in printed circuit board applications, the typical Cu thickness is 50 to 75 micro inches. Heavier thicknesses for this application the Cu tends to peel upon itself. ElectroLess Cu does not contain any brighteners or levelers which are essential for a good deposit which is a lot less porous and thicker.
Engineering - Mesa, Arizona, USA
First of two simultaneous responses -- March 27, 2012
Second of two simultaneous responses -- March 28, 2012
Dear Abhiraj Naik,
The major difference in plating a metal by electro- and electroless route is the uniformity of the coating.
Coatings deposited by electroless deposition method is uniform irrespective of the geometry of the job
In electrodeposition process, there will be overgrowth at the edges, which requires post-finishing
Plating rate, bath stability and number of turnovers are good in electrodeposition whereas these aspects are relatively poor in electroless deposition
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
