Safe, practical and easy way to remove Zinc coating
What is the safest, cost effective and most practical way to remove the Zinc coating from the inside and outside of Galvanized Sch.40 Pipe, in order to weld two pipes together?
Tim YaceykoPipe Fabrication Facility - Edmonton , Alberta, Canada
Hello, Tim. Have a plating shop dip it in dilute (10-20 percent) hydrochloric acid for you. Good luck,
