Thread 363/72
Paint adhesion to Mg (AZ91D) Thixomolding part - what are the factors
Hi,
I have problem of keeping the production of the paint within the spec of preformance.
I'm mainly speaking on 2 issues:
1. Adhesion test (post thermal+humidity of +65C/90 % R.H for 48 hours) .
2. resistance to sun tan lotion , which imitates to some extent the oils that this part may come in cotact during it's life.
I know how to control the process of the painting + passivation
(passivation is "Shadan" passivation), still there is a large variance between 2 lots subjected to the same test.
My Question is (ignoring the paint material):
1. Are there inner Magnesium material cause effects? I.E, is the Mg casting still active post passivation and does this contribute to the paint's reduced preformance?
2. Is there a minimum time period between passivation and painting process?
Thank you in advance,
Mechanical Engineer in a Telecommunication Company - Tel Aviv, Israel
publicly reply to Yonatan Kemelman
Yonatan, I do not know what is "Shadan" process, but it does not look like something for magnesium. 48 hours is very low requirement.
We already many years work with magnesium and we have coating line in Israel as well supply chemicals to other countries.
You can contact us by Chemetall or by Israeli Magnesium Users Association (there know me very well)
- Frankfurt/Main Germany, Alonim Israel
publicly reply to Ilya Ostrovsky
Magnesium is not amenable to the normal "passivation". Magnesium is way too active. That said, I do not have any constructive suggestions other than trying the same process with AZ91HP.
Pat Reid- Costa Mesa, California, USA
publicly reply to Pat Reid
