  Thread 363/26
Aluminum alloy 7075
Pl. suggest can we use the aluminum alloy 7075 for manufacturing Jigs & Fixtures required for production of motor-cycle parts.Also,suggest tempering required & Surface treatment required for anti-corrosion of the same when used with coolant.
SANTOSH SHANTARAM DENGLE
BAJAJ AUTO LTD. - PUNE, MAHARASHTRA , India
publicly reply to SANTOSH SHANTARAM DENGLE
What material and finish are you presently using, and what problems is it causing?
publicly reply to Ted Mooney
Dear Sir,
Presumably these are for movement of components? You can simply anodise them and apply a marine paint topcoat.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
publicly reply to Khozem Vahaanwala
