Canning Black Chrome Plating - Insoluble catalyst component?
     Chrome plating only works when there is an almost exact ratio of chromic acid to catalyst. Special partially-soluble fluoride compounds can help maintain that correct ratio automatically. Please see our FAQ on Chrome Plating Catalysts.
The Chrome Poem
Chrome Poem
Q. We are a commercial plating plant based in New Zealand. We run a Macdermid/Canning Black Chrome. The catalyst appears to consist of three components. When we mix the catalyst into the solution one component doesn't fully dissolve and forms a fine precipitate. I would like to know:
1. Is this normal?
2. Is this a fluoride compound that is partially insoluble and present to help maintain a minimum concentration of fluoride, i.e., as the fluoride concentration decreases the compound dissolves to replenish it?
3. Would anyone be able to tell me what the compound is?
Simon Lee
electroplating shop - Auckland, New Zealand
A. Hi Simon. Per the Canning Handbook:
36322
So, yes, it sounds like this solution contains a partially soluble fluoro-silicate or similar catalyst.
There must be a reason you are not asking Macdermid? Obviously, they can't tell you everything about their proprietary products, but they can certainly tell you the answers to your first two questions?
thumbs up signYou would think so, we asked but they didn't know.
Simon Lee [returning]
Q. Hi Mr Simon Lee,
We have a stock of Canning black chrome additive but because it is classed as an export item only from UK, I have been unable to get a datasheet from MacDermid. It appears that you run this process and I would like to ask if you have the additions information datasheet?
We currently run black chrome but the solution is getting a bit tired, and I would like to make up new solution using black chrome addition agent.
I would be most grateful if you could assist me in this matter. Thank you
Ken Perks
- England, UK
January 6, 2014
"The Canning Handbook of Surface Finishing Technology"
canning
or eBay or
A. Hi Ken. Simon's posting was from many years ago and we're not sure how to reach him or whether he ever views this page anymore.
But the Canning Handbook has several pages about black chrome plating, with data sheet information on the Econo-Chrome BK bath (assuming that is what you have).
The handbook notes that the trademark is owned by DuPont. That may be dated info considering the way companies are bought & sold, with today's CEO's constantly playing at pitching pennies with people's livelihoods, but the point is that you'll find that Econo-chrome BK is a widely used bath, not just a Canning product, so you may be able to get a data sheet from another vendor. Good luck.
