ADC-10 Aluminum Alloy Environmental Properties
I have some diecast boxes made from ADC-10 Aluminum Alloy and I wanted to know if they would tolerate 0 to 95% relative humidity without corrosion.
Edward Marden
aerospace systems - Hudson, New Hampshire
Ed,
If you plan to anodize these boxes, they should withstand humidity. But does your querry include a salt spray test?
Michael Null
plater - Methuen, Massachusetts
ADC10 is an aluminum material used for die cast parts. What is an equivalent aluminum type to be used for sand casting?
Marcello Tedesco
- Shelby Twp, Michigan
January 21, 2010
