Stripping zinc phosphate
Question: We have pieces with zinc phosphate that need rework. What acid is needed, sulfuric or hydrocloridric?
Cesar Lopez
- Mexico
Dear Mr. Lopez,
If the substrate is steel, You can use the following solution to strip the phosphate coating on it:
Concentrated hydrochloric acid containing 20 g/l of antimony trioxide,
This solution is very effective in removing the phosphate coating on steel and at the same time prevents the attack of the base metal.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
Hydrochloric acid is better.
v g rajendran
V. G. Rajendran
- Trichy, Tamilnadu, India
