Zinc Plating vs. Black Oxidizing
I am currently having spring steel parts zinc plated but am having a problem with brittleness. The parts are cracking. How good an option is Blackodising. Will it corrode and rust over time compared to the zinc plating?
Electronic parts - India
Black oxide offers no corrosion resistance at all (except for the oil that is usually put on it). Spring steel parts should be properly baked for hydrogen embrittlement relief.
