Looking for unsharpened razor blade source
Q. Looking for source for unsharpened razorblades for thickness testing purposes.
David M. Weaver [deceased]
- Toccoa, Georgia
Ed. note: With great sadness we must advise that David passed awayt on Aug. 15, 2003.
A. Palm Commodities out of Laverne, TN supplies unsharpened razor blades.
Megan Pellenz
Megan Pellenz
- Syracuse, New York
Razor blades as plating thickness measurement coupons?
Q. What is your opinion on using razor blades for coupons to measure the plating on steel? The measurements are wack and the blade seems to be shrinking due to the chemical. This is in regards to the nickel plating process.
GUNTHER BUMPKIIN
- HARRISON. Arkansas
February 6, 2020
