High temperature coating using metallizing
I wanted to know whether there is any way to coat C.I. Surfaces to withstand up to 1000 degress centigrade by the process of metallizing where I cannot spray Stainless Steel as the pipe would be used in the presence of Fluorine Gas which reacts to the nickel in the S.S.
SHANTANU NEWAR
METALLIZING - CALCUTTA, WEST BENGAL, INDIA
In my opinion, most any metal or alloy will react in the presence of fluorine gas at 1000 °C. Oxides, carbides, silicides, nitrides or cermets are out of the question. Probably not even gold could prove resistant due to temperature. Only platimun or iridium may be a possibility.
Guillermo Marrufo
Monterrey, NL, Mexico
