Permanent black finish for mild steel
I want to get permanent black finish (dull finish) for mild steel pipes. How can I get that?
Reji JoseTeam Architectural Ornaments - Dubai, UAE
Black paint, black powder coating, ceramic coating, black e-coating, autophoretic coating, black zinc-iron plating, black nickel plating, black chromium plating are some of the possibilities that come to mind.
Dear Reji,
Addition to Mr Ted response I want to add you can go for hot or room temperature blackning or zinc plating with black passivation and then seal it .
- Ajman, UAE
