Bubbles on Plated Plastics
Is there any solution to perform etching on plastic materials with different porosities ( in which the problem is porosity-measuring for each different plastic material to be etched is too technology- and time-consuming) without over-etching or under-etching to cause bubble problems and et cetera? Any certain chemical or method for this big problem?
Ivana
PT Indoplat Perkasa Purnama - Jakarta, Indonesia
It's not possible to toast bread with that philosophy, let alone plate plastic :-)
