Stripping Hard Coat Anodize
What is the best way to strip hard coat anodized parts? Pitting and base metal etch is not an issue. Solution must be able to operate out of a stainless steel tank.
Bill Griffin
- Waterbury, Connecticut
Bill,
Try straight caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] and heat it up to 160-180 °F - same as hot caustic etch. Otherwise might try chromic / sulfuric mix found in most trade references, however, this likely to attack stainless. While chromic / sulfuric is more gentle on the basis aluminum once the anodic layer is stripped, the hot caustic etch can't discern the difference between aluminum and aluminum oxide - it's not likely to pit but will remove appreciable aluminum!
milt stevenson jr.
Milt Stevenson, Jr.
Syracuse, New York
We have had good success, without base material problems, using a solution makeup of 20 g/l chromic acid and 85% phosphoric acid at 3.5% by volume operated at 212 degrees F.
Tim Martin
plating shop - Springfield, Massachusetts
