Removing chrome plating and nickel from aluminum valve covers
Howdy:
I recently came across a pair of vintage Edmunds valve covers for my Cadillac 331 motor and (arrrghhhh!) they have been chromed. Is there any way to restore them back to their original 1950's vintage aluminum finish or at least a polished finish?
Craig
Craig Anderson
hobbyist - Bryan, Texas USA
The easiest way would be to take them to a plating shop which can strip them by immersion in nitric acid, or by reverse current in sulfuric acid. They can then be polished and buffed by them or by you.
To add to what Jeffrey said, although the process of stripping nickel from aluminum with nitric acid is simple enough none of the processes for chemically removing plated metals should be done at home!
Gene Packman
