Mask and de-mask solution
We are currently doing stripping for aluminide coating and wish to mask the uncoated area. we are looking for some maskants which can be removed easily after the stripping. Can anyone recommended an approach?
Chee Wong SiewAviation - Kuala Lumpur, Malaysia
You forgot to say what method you are using for the stripping. Mechanical, chemical?
We are currently using a chemical stripper to strip off the aluminide coat but due to the some uncoated area, we need to look for a suitable mask to prevent chemical attacks.
O.K. What kind of chemicals are in your stripper, do you know? Organic acids, mineral acids, strong oxidizers or other compounds? This information is necessary to properly suggest.
Well, we are using a mixture of nitric acid with ammonium Bi-Fluoride (the original product name is ASC-2N). This mixture of chemicals are very aggressive especially the temperature exceeding 90-100 deg F.
Chee Wong Siew- Kuala Lumpur, Malaysia
We are using a mixture of nitric acid and ASC-2N (ammonium bi-fluoride) chemicals. We will dip the parts in this mixture for an hour at room temperature, 30 °C.
There are wax based stop-offs designed to withstand around 45 °C (120 °F) operating temp. You may try them. They are removed by petroleum based solvents. Otherwise there is a PVC tape that is self adhesive over itself that can be overlaped (no adhesive as it will not stand the mixture).
Are there any more kinds of maskants that can be burned off after use?
The best method is wax. e.g Cannings Clamca wax. It can be applied by melting in a domestic electric chip pan and applied by dipping. 3 dips are recommended for complete coverage. Sapura MARS is using this method in Klang, Malaysia.
John Dodgson- Kuala Lumpur, Malaysia
November 13, 2008
finishing.com is possible thanks to our supporting advertisers, including:
