Sodium Carbonate in Sodium Hypochlorite
Q. THEN WHAT CAN YOU USE TO STABILIZE SODIUM HYPOCHLORITE?
TSHEPANG MOLETE
- GABORONE, Botswana
January 19, 2022
A. Hi TSHEPANG. One answer is 8-hydroxy quinoline according to patent application CN1597497A as revealed by google. Keeping concentrations below 7.5% will help. Apparently, boric acid or sodium bicarbonate can be used for very low concentrations.
A google search for "STABILIZE SODIUM HYPOCHLORITE" shows dozens of long and very interesting articles on the technology of sodium hypochlorite stabilization. This forum can be good for getting input towards resolving a highly detailed very specific problem, but I don't think we can cover the whole broad technology of that general subject. Good luck!
Say hello to Mma Ramotswe and Mma Makutsi for me -- two of my No. 1 Ladies.
January 2022
Q. I am doing a project about sodium hypochlorite as the term for finishing my bachelor degree education in my university.
I have several questions below:
1. How could sodium carbonate this on eBay or Amazon] form in sodium hypochlorite
2. Could sodium carbonate stabilize the sodium hypochlorite solution? If it could, how does it work and how much sodium carbonate concentration is allowed?
I am waiting for your answers.
Best regards,
Revan Afza
College student - Riau, Indonesia
A. I could be wrong, but I seem to remember from my early industrial chemistry classes that commercial hypochlorite is made using sodium hydroxide and chlorine gas. Sodium carbonate is present in the sodium hydroxide as a byproduct so it ends up in the hypochlorite solution. Max limits are up to you and your supplier. I'd start looking on the net for sodium hypochlorite manufacturing processes and go from there.
Trent Kaufman
Trent Kaufman
electroplater - Galva, Illinois
A. Hi.
I was searching for Sodium Hypochlorite in Indonesia and found your site.
As mentioned before you could search for manufacturing or the product Sodium Hypochlorite and you'll probably end up with heaps.
Here is a link you could check up on.
http://www.orica-chloralkali.com/BUSINESS/CHE/CHLORALKALI/CHE00139.NSF/Page/Products_Sodium_Hypochlorite
Jan [surname deleted for privacy by Editor]
- Perth, Australia
Ed. note, Jan. 2022: Unfortunately that link, like 99% of old links, is broken.
A. Sodium carbonate is often formed as an impurity in sodium hydroxide solutions. It is made by the carbon dioxide in the atmosphere dissolving in the caustic soda and forming sodium carbonate. It is usually seen as a white powder on the neck of the containers. I have never heard of it being used to stabilise hypochlorite, but if it does, it could be because it helps to keep the pH on the alkaline side, thereby reducing the propensity of the hypochlorite to release chlorine gas due to a shift in pH towards acidity. I wouldn't use sodium carbonate as the main stabiliser for hypochlorite, as I cannot see it being very effective in the long term.
A. A water solution of sodium hypochlorite will decompose sodium carbonate slowly under atmospheric pressure. If the O- radical and CO2 leave the vessel, the reaction shifts to the right and sodium chloride is formed. In a tightly closed flask the reaction will only slightly proceed and an increase of pressure will be observed.
Jorge Velásquez
- Medellín, Colombia
