Are brass valves suitable for DI Water?
Hello we are installing a system with DI spray and adds we have used pvc supply line and electric brass valves for automation will the Di water effect these brass valves.
Thank You
- West Plains, Missouri
Very high grade DI water will errode brass faster than most people will believe. Low quality DI will give a slow gradual attack on the brass.
It will definitely reduce the quality of the water. If you pay good money for DI, why add copper and zinc ions back into the water? Teflon valves cost several times what brass one do, but are as good as you can get.
Some pvc sprinkler system solonoid valves have no metal contact with the water and would work great at a very affordable price.
Only if you don't mind replacing them every 4-6 months or so!
DI water will leach the zinc out of the brass, and eventually cause you problems. You'll notice that there is also a whitish smut that will appear on parts.
Tom Baker
wastewater treatment specialist - Warminster, Pennsylvania
