Release problems in CD molding
Dear all,
We have release problems when we mold CD discs with microstructures. The mold tool is made of Ni and the polymer is Zeonor 1060r. The problems doesn't start until a couple of hundred discs have been made. The surface of the mold tool is in the beginning hydrophobic 90 degree wetting angle and after a couple of hundred CDs the wetting angle is about 60 degrees and then the problems with release begins. We have been trying some surface coatings like DLC TiN, but none is working.
Is there anyone that have experiences from Zeonor 1060r or any other zeonor please contact me.
- Uppsala, Sweden
It's sound to me at your nickel plating is to soft. To solve yor problem here you must describe more about it.
Anders Sundman
Consultant - Arvika,
Sweden
My experience using EN for molds is that the release is better using high phosphorus 10% by wt. or higher phosphorus content.
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
I know exactly what the problem is, it is the photoresist not being removed off of the stamper. You need to use an electrocleaning process to remove the PR.
Sorin Diosan- TN
