Residual current of anodizing tank
Hi
I have been anodizing for five to six years now, and have come across some interesting problems. Most I might add I have sorted through the help of others through your excellent web site Ted.
My latest puzzler is after anodizing,I turn my amperage control to zero,and usually there is a rapid drop of amps on my ammeter.After which I turn off the power.Now after turning the amps down there is a very slow drop in amperage almost as though there is a residual current still in the tank.It can take up to15-20 minutes to dissapate the current stored in the tank.
Any ideas?
I have cleaned all my connections,changed my sulfuric acid solution.installed fresh 6063t5 cathodes but no joy.My next line of thought is my rectifier.It is home made but has been desined by a professional electronics firm and still works great.
Thanks for any info
Steve Power
Aircraft Engineer - Nelson, New Zealand
There is a very strong galvanic voltage between titanium racks and aluminum cathodes. Also betwewen lead and aluminum. And just a little bit between titanium and lead. Get a meter, go measure, and let us all know what you are finding. We would also like to know the concentraiton of the anodizing solution along with the voltages you find.
robert probert
probertbanner
Sorry for the delay, Robert.
I am using alloy wire(1100 series) to connect my parts.A typical anodizing run,say about 30-50 amps at 1.5 amps per square decimeter, My voltage sits at around 14-18 volts,depending on load.Amperage is controlable,voltage is not.I have connected my rectifier to a series of aircraft landing lights to simulate a load,and used the amperage control as a dimmer,the lights dim and shine with the amperage control,so I can assume my rectifier is working just fine.My acid concentration is 190-200g/litre free sulfuric acid.The voltage drops at the same rate as the amps after turning the amperage control to zero.ie very slowly. Hope this info helps
Kind regards,
Steve Power
