Converting from Cyanide to Alkaline base on Zinc Plating
Q. I'm in an industrial training, So the company want me to make an idea belong how to change the Cyanide that are using in Zinc Plating convert to Alkaline base?
Shah- Malaysia
Tip: This forum was established to build camaraderie among enthusiasts through sharing of tips, opinions, pics & personalities.
The curator & some of the readers who publicly share their info are unlikely to engage with posters who don't.
A. If you are presently using a cyanide containing zinc bath you are using an ALKALINE CYANIDE bath. If you want to explore a non-cyanide alkaline bath these are widely used. However, it is generally not feasible to convert [do a sliding conversion] from cyanide to non-cyanide because of the extended time required until the cyanide is completely consumed in the process.
Gene Packmanprocess supplier - Great Neck, New York
A. Mr. Packman, above, is 100% absolutely correct. I express the same thing this way: If you slide you will create more cyanide bearing sludge to haul away than if you just waste treat the whole CN bath and start from scratch with the Caustic & Zinc. I learned that years ago while involved in changing over a 40,000 gallon zinc solution. ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() A. Mr Shah ![]() Asif Nurie [deceased] [deceased] - New Delhi, India With deep sadness we acknowledge the passing of Asif on Jan 24, 2016 |
A. Hi!
You can find some useful information on website pfonline.com in section "articles" in article #049702, or ⇩ Google it with text string "pfonline anatomy of a conversion"
Maybe this can be a little bit helpful.
Best regards!
- Kranj, Slovenija (EU)
Ed. note: Pfonline is re-arranged, but the googling works :-)
Indeed it is helpful, Dimitrij. It also suggests replacing cyanide with non-cyanide outright, not wih a sliding conversion.
