Chemical cleaning a dark deposit from surface of aluminium engine block casting
We have a number of engine blocks that need to be cleaned to remove a dark grey deposit from the cast surface.
We have tried 20% Nitric acid, 10% phosphoric acid, petroleum spirit, and toluol with limited success. The deposit could be a burnt on die lubricant as it feels a little greasy.
I need to organise the treatment of over 100 engine blocks to remove this stain but am at a loss as to what will work without attacking the cast iron cylinder sleeves.
Can you help
Graham Dodd
Automotive - Melbourne Victoria Australia
Hello Mr Graham;
Use your nitric acid cocktail after swaying your blocks around in a solution of 50 - 100 gms per litre of Sodium Hydroxide for 20-60 seconds first and rinsing afterwards. This won't affect your steel Liners but will effectively etch the aluminium first.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
