Electroless Plating Compatible with Sulfur
What other electroless platings are available?
I have found that Electroless Nickel works very well with rubber with cure systems other than a sulfur cure.
So, now I am looking for an electroless plating that is compatible with sulfur cured rubber.
Darrell Elkins
Manufacture of Rubber Products - Elgin, Illinois, USA
You might want to look at an immersion plating from a bath of Copper and Stannous sulphate with a ratio of 100:1
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
Khozem,
Thanks, I will check into copper and Stannous sulphate.
Darrell Elkins
