Zinc as electrolyte produces slow results. How can I speed up the process?
Hello! I am a Secondary Four student doing a project on electroplating...and I have used vinegar
⇦in bulk on
Amazon [affil links] as the electrolyte...however, the process took almost 45 mins. However, when I use copper (II) sulphate solution or dilute hydrochloric acid, the object gets electroplated within 15 mins. Is there any way I can speed up the process of electroplating while still using vinegar as the electrolyte?
Student - Singapore
Probably not. vinegar is a very mild acid and can only hold a very small amount of copper or zinc in solution. You can't plate the metal out of solution any faster than it dissolves in.
Try using a larger container of plating solution so that it will not go low on the zinc in solution as fast. Also , slightly increase the agitation so you get new solution to the cathode faster.
James Watts- Navarre, Florida
Vinegar basically contains acetic acid ⇦ this on eBay or Amazon [affil links] . In order to make the electroplating more effective either you need to alter the electrode potential. However, as Mr Ted pointed out, it is a difficult task. you can try heating up the electrolyte and slightly diluting it with HCl.
Manuj Kaushesh- Solan, H.P, India
