Painting over powder coated aluminum
How do you paint over powder coated aluminum windows?
Colin Rossprivate - New Zealand
Are you talking about installed window frames? Clean the window frames with hot soapy water, mask off what you don't want painted, clean again with a rag and alcohol (denatured not 90 proof) and use a spray paint that has MEK / methyl ethyl ketone as one of it's ingredients. The MEK will soften the powdercoat and help with adhesion.
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
