Fluorine retention on anodized aluminum surfaces
Is there any literature that would compare the fluorine retention of both anodized and un anodized aluminum surfaces in a vacuum. In the semiconductor industry fluorinated gases are used under vacuum to clean previously deposited materials. Post clean, some vacuum chambers seem to retain a larger fluorine signal for longer periods. There are several versions of chamber some having more anodized hardware than others. Any info would be helpful.
James N.Pinto
Semiconductor Manufacturing - Burlington, Vt, USA
Good luck finding specialized data like that. The equipment manufacturers usually do not disclose a lot of info that they pay handsomely to research.
If it helps..
Anodized CVD components typically are .0020" hot water sealed, and etchers are .0020 with a nickel acetate seal.
I would suspect if the components were not sealed (properly) you might see some retention/outgasing. Unsealed, the coatings will adsorb as well absorb.
Willie Alexander
Qualtek Manufacturing - Colorado Springs, Colorado, USA
