DIE ATTACH DELAMINATION
WOULD LIKE TO SEEK YOUR OPINIONS RE D/A DELAMINATION ON SOFT SOLDER PROBLEMS WE HAD ENCOUNTERED. WAS ABLE TO PERFORM EDX ON THE DIE BACKSIDE OF THE SAMPLE REJECT AND THE FOLLOWING ELEMENTS WERE TRACED: Si, Al, Cu, C, and O. DO YOU THINK Al WAS THE MAJOR SOURCE OF DELAM? IF YES, WHY?
JOJO VICTORIO
- MANILA, PHILS
We will need more information Jojo or maybe I just don't understand.
What is the composition of the solder?
What is the solder temperature?
Is a flux used and if so what type?
Are the surfaces cleaned prior to soldering.
What materials are you soldering together?
Aluminum is a difficult material to solder because of the oxide that it forms. A chromate or phosphate coating may help.
Rick Richardson, MSF
Dayton, Ohio
