How do I quick oxidate brass to get a black finish?
How do I quick oxidate brass to get a black finish? After the black finish I need a green corrosion on the top.
Markku Timo
Brass items - Sweden
For small pieces You can use 200 gm copper carbonate this on eBay or Amazon [affil links] / 1 lit ammonia this on eBay or Amazon [affil links] solution (cold immersion process, bad smelling, work outside, protect your eyes and hands). If You want to add some green patina after that You can use 250 gm ammonium carbonate/25o gm ammonium chloride/1 lit water solution. Only grease and oxide free objects can be coloured!
