HCl Purity Test
Hi,
We are using 6N and 2N HCl (Purely Laboratory purpose acid) for Sample Dissolution. But I want to know that how pure are these acid. Is there is any procedure to check the purity.
Dipak Kumar Panda
Physical Research Laboratory, Govt unit - Ahmedabad, India
What impurities are you concerned with? By "purity" do you possibly mean strength or concentration? If you buy analytical reagent grade acids, they come with a typical analysis. (at least in the USA)
Since you don't know what impurities it may contain, you need to do a full cation and anion analysis. Virtually all cations can be done by ICP with relative ease and in one shot, but anions may need a bit more diligence. try doing conventional tests for sulphate and nitrate as a start.
