Cleaning and restoring a brass ship's bell
Q. Which would be the best procedure-an alkaline soak or an acid treatment for restoring a not too large old ship's bell?
thank you
Richard Marquart
hobbyist - Durango, Colorado, USA
A. You can use 5% ammonium citrate solution(mix 50 gm citric acid this on eBay or Amazon [affil links] and 1 lit water,add some ammonia,pH must be 9).
A. Hi Richard, Check out letters 25955 and 26729, they may help you out a bit.
Good luck,
Jim Gorsich
Compton, California, USA
