Brass etching
What is the standard time & mixture used when etching?
We currently use 1 FeCl :3 H2O @ 3-4 hours. is this a recommendable one? how could I reduce my time with same quality? what are the important point during etching?
Thanks a lots to those who can help & give me ideas..
Caryl Misiona
Cebu Etching - Philippines
HI,
I ASSUME THAT YOU WOULD LIKE TO ETCH BRASS, THE STANDARD PRACTIVE FOR ETCHING IS 10 TO 15 PERCENT OF sulfurIC ACID SOLUTION AND THE DWELL TIME IS 10 SECONDS.
TRY THIS AND SEE THE RESULTS , BEST OF LUCK
VIDU GOYAL
- INDIA
Hi Caryl.
I am from Legazpi City. May I ask, what do you use as a resist in your brass etching? I hope you could help me. thanx
Charles Xavier
- Legazpi City, Philippines
Hi! Please help me... I'm new in brass etching, I would like to know what is the standard ratio or correct mixture of chemicals (Photosynthesizer) in brass etching? that may result to shorter and quick time in etching and has a good quality too.
Your quick answer is very much needed. Thank you so much.
Best regards,
Gail
GAIL ABARQUEZ CRUSE
- Talisay City, Cebu Philippines
Hi my name is Ashutosh I am currently into manufacturing of trophies in which I have to have a brass plate which has to be etchied I need to learn the entire process which is cost effective and quality oriented.I need to know the exact propotions of the chemicals used.
Ashutosh Punekar
trophy manufactuere - Mumbai, Maharashtra, India
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
