Hobbyists & Industry luminaries alike learn on every visit
(we earn from 'affiliate link' purchases)
Coating for titanium
1/ We are working on assemblies tha thave titanium and steel parts. Is there any kind of coating that could be applied to the parts after they are assembled.
The design is currently all steel parts that are assembled and then finish machined to the tight tolerance required in the assembly. We want to switch the major parts to titanium to reduce weight. Any suggestions on a coating that could be applied after the assembly and finish machining.
2/ If there is no solution to question number one. What are good coating for titanium for wear resistance?
Olivier Coulombier
weapon manufacturer - South Carolina
I would suggest you consider PVD coatings, such as TiN and ZrN. These are deposited regularly on titanium by my company and others for wear resistance with excellent results. Because the coatings are very thin (3 to 5 microns), they don't affect the part tolerances.
jim treglio portrait
PVD Consultant & Wine Lover
San Diego, California
Electroless Nickel can be plated on those substrates very uniformly with a 60RC hardness.
Todd Osmolski
- Charlotte, North Carolina, USA
All depends on the dimensions and some structural peculiarities of your parts. Titanium doesn't like to be applied as substitution without any design correction. As for coating - the best practical way is oxidizing if some conditions are permitted. .
Andrey.
Igolkin
prometey - Russia
