Tin plating
We are supplying fuse holders to electrical and electronic industry. Plated connects are used for fuse holder.The detail is -Sn - 8 micron over coating.Ni - 2 micron under coating.I am having one doubt that if plating brightness increases, it will affect to the solderability of connect ?what is the diff between Vibratory plating and barrel plating ?what is the normal productivity of these method ?which method is best ? and why ?Please clarify my doubts.Waiting for your reply.With best hopes
SPS.Rao
manufacturing of fuse holder - New-Delhi, INDIA
Hello Mr Rao,a. The higher brightness may affect the ductility and solderability to a nominal extent.b. Vibratory barrels are not available in India and Barrel plating is the common procedure used by most platers as it is fast and cheap.
However your question doesn't state why you want to know either or what the objective of your query is.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
