Removing Aluminum Oxide from Aluminum metal
Can I use Phosphoric Acid to clean Aluminum Oxide from Aluminum Metal?
Alan Charles HughesRetired - Liverpool, United Kingdom
Yes you can.Use 2oo ml phosphoric acid/ 1 lit water solution,45-9o C temp.Good luck!
Goran Budija- Zagreb, Croatia
