Plating on plastic
Hi
I'm currently doing electrogalvanizing here in the Philippines and just recently I have a client who wants his Toyota car EMBLEM electroplated but the problem is that it's base is plastic. If you can help me I want to know the process and the chemical solutions to it.
Sammy Barramedaplating shop - Philippines
Sammy,
Believe me you don't want to plate that gentleman's emblem.
(unless he wants several thousand per day and happens to work as a buyer for a large autoparts manufacturer). A conventional POP (plating on plastic) line consists of at least 22-26 tanks and will cost you anywhere from $200,000 to $1,000,000 US dollars all equipped, filled with chemicals and ready to operate. Without it you cannot do a decent POP job.
