Cleaning EP Brass
I want to clean my E.P Brass tray. Should I use brass or silver polish?
Karen
student - Chicago, Illinois, USA
I was doing some searching on what to use to clean EP Brass. I have tried silver polish as well as Arm & Hammer washing soda this on eBay or Amazon [affil links] and aluminum. It did work a little but did not give the results I was hoping for. Any advise or tips would be appreciated.
Best regards,
Lorraine Hunt
- Jackson's Point, ON, Canada
Karen, are you saying this tray is made of brass and is electroplated with silver? If the surface is brass, use brass polish; if the surface is silver, use silver polish.
Lorraine, to clean silver you may want to view letter 4785 again. I did that aluminum foil and washing soda this on eBay or Amazon [affil links] procedure myself just this week and it works well. The hotter the water, the better. But it's possible that there is not much silver left on the item; you may want to send it to a shop to be electroplated again.
