Tin plating humidity resistance
HAI,
1)PLEASE LET US KNOW WHETHER BRIGHT ACID TIN PLATING WITHSTANDS ENVIRONMENTAL TESTING AT 65DEG. C & 90% RH FOR 300 HOURS.
2)IF YES WHAT ARE THE THICKNESS AND OTHER PARAMETERS TO BE MAINTAINED.
3) WHICH CHEMISTRY SUPPLIERS ARE CAPABLE OF OFERING THE SAME.
SE.RAMAMOORTHYHYDERABAD LEXTECH LTD. - HYDERABAD, AP, INDIA.
Dear Mr Ramamoorthy,
What is the substrate over which Tin is plated? A short answer is also NO for the 300 hours.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
