Aluminum expansion
If one has an aluminum piece, such as a carburetor, with a shaft or a hole in it, through which a spindle is inserted, upon heating the unit , under hood temp to expansion temperture, does the hole or shaft, expand, or, contract.
Peter Gabriel
car buff - Douglaston, New York, USA
The tricky one is the hole, but the answer is a hole gets bigger when heated. Alice's mouth is bigger after she eats the magic mushroom.
