Can Nickel plating on aluminum part be welded at 220 °C ?
We need to Nickel plate an aluminum part that will be soldered at 220 °C (reflux), for 1 minute, can this be done? What will be the best process to obtain such a finish. The part is an aluminum plate, I don't know if it is extruded aluminum. I've heard of the typical process, with a double zincate, but then an alkaline electroless nickel, is this the right way to go?
Please advice, and thanks for your help
- Guadalajara, Jalisco, Mexico
Yes it can.
Anders Sundman
Consultant - Arvika,
Sweden
Anders,
Thanks for your answer, could you elaborate a little ?
The part is made of Aluminum 3003-H14 and we require to apply a 0.0001" to 0.0003" thickness Electroless Nickel.
What will be the best process for this application?
Thanks for your help
Sergio,
Aluminium from 3000 series contains magnesium so you must use a sulfuric acid dip at last step before zincate. Did the zincate in two step there you dissolves the first zincate films. On Aluminium alloys who contents magnesium will in nitric acid build a film who are hard to removing from the substrate, in sulfuric acid this film changes to a easier film to remove. To get a better adhesion heat treatment after you have plate the aluminium in temperature to 190-200 °C for 1 hour.
Anders Sundman
Sweden
Anders,
Thank you for your help.
We'll try your suggestions.
Best Regards
Job Shop - Guadalajara, Mexico
