Stripping Nickel and Electroless Nickel Plating from Brass
Q. What is a good chemical-free way to remove nickel plating from brass?
I want to strip the nickel plating from some old watch cases so that I can re-plate them. Watch cases are more often than not a brass base with a nickel or gold coating (but for now I'm just practicing on nickel). Currently, some of them are just in need of replating, but are otherwise free of oxidation and corrosion. Some are in dire need of a complete stripping and cleaning of corrosion.
I've seen lots of suggestions of people suggesting the use of hydrochloric/nitric acid to remove it. I don't know if that would fix the issue of corrosion, but most importantly, this has to be wife-friendly. There's not a snowball's chance in heck that my wife would be cool with me using such acids in our small apartment.
My search has led me to rotary and vibratory tumblers as a means to, depending on the media, both strip the nickel, mechanically remove the corrosion, and probably with a different media, polish it to a shine to prep for replating.
Does anyone have experience with this and can give me some advice, or perhaps suggest a different way?
- Pelham NY
May 20, 2021
Q. I would like to know if there is a process to strip electroless nickel plating from low lead brass.
Robert SachsSybron Dental - Morrisburg, Ontario, Canada
A. Yes, there are a few proprietary products available that will strip EN from brass without many of the nasty chemicals often found in home brew recipes. What type of EN are you stripping? Low, mid or high phosphorous? Is it baked? Each of these variables will determine the proper chemistry. I would suggest contacting an EN chemical supplier.
Dan Brewerchemical process supplier - Gurnee, Illinois
A. Try a mixture of concentrated nitric and phosphoric acid. Alternatively there are a few solutions that are claimed to strip nickel from brass:
1) 18 g/l HCl + o-phenylamine - anodic dissolution at 35 ASF
2) 10% HCl
3) "Dekote A" 110 g/l + H2SO4 50 ml/l (Cannings)
4) 60-90% H2SO4 + 30 g/l Glycerine
5) 10% HCl + 5% H2O2; this may also go for the brass!
A. NaOH ; 60 g/l
ethylenediamine :120 g/l
MNBS (m-nitrobenzene sulfonic acid) : 60 g/l
TEMP : 170 °F
^-- ABOVE METAL FINISHING GUIDEBOOK 2001 --^
OR NaCN 60 G/L , MNBS : 80 G/L , NH4OH : SMALL TEMP : 140 °F
- Korea
Strip nickel plating from a vintage brass saxophone
Q. I am in the process of restoring a valuable vintage saxophone that has been nickel plated. We need to remove the nickel plate to restore the finish to the brass underneath. What is the best way to strip off just the nickel, leaving the brass body & keys of this instrument smooth & clean?
Barry 'Bear' Wilsonvintage saxophone restorer - Tulsa, Oklahoma
A. There are proprietary stripping processes available from suppliers such as Macdermid, Enthone etc (based on acidified MNBS (m-nitrobenzene sulfonic acid) with activators/inhibitors) which can do this job. Ask your local plater.
Geoffrey Whitelaw
- Port Melbourne, Australia
A. You can strip it electrolytically! Use 5% nickel sulphate or chloride solution and 4,5 V battery(cheapest); object=anode(+); cathode(-)= SS!
Stripping satin nickel plating from brass
Q. Hello...
We plate lock parts made of brass. We plate satin nickel directly without copper. But when we want strip them, sometimes we don't succeed. Because, I think satin layer is very different, I mean very hard to strip them. But some parts strips normal not very hard. But satin parts very hard to strip. But why? is it skin difference? Also could you give me a formula for satin nickel strip over brass? It can be electrolytic or electroless, doesn't matter.
engineering - Duzce, center, Turkey
Q. What is the best way to remove the satin nickel finish from brass hardware?
Earl Brydson- Tacoma, Washington, USA
July 3, 2013
A. It is risky and has to be closely monitored because if you walk away and come back the next day you could be in for a world of hurt. In other words, the solution attacks nickel but also the underlying material as soon as it is exposed. You can buy proprietary Ni stripping solutions from your friendly neighborhood chemical supplier or you can use a combination of sulfuric, phosphoric and nitric acids. Try one first because you will probably need to do a lot of fine-tuning and could see pits and other problems that will make you want to change certain parameters.
Blake Kneedler
July 12, 2013
A. Hi,
Satin nickel is electroplated. So, some parts will have more nickel than others. So, some are stripped easily and others...
To be made easily :
- 750 mL/L sulfuric acid 92%
- 3% vol. glycerin
- lead anode
- anodic, 10 to 20 Amps/dm2
If parts are greasy or handled, try to dip into an alkaline chemical degreaser before stripping.
Do not try to remove the complete plating. If plating resists on edges or corners, remove mechanically. Otherwise brass will be lightly eaten.
Before stripping production parts, some loose sheets freshly nickel plated shall be used to make older the stripper. Because, in the beginning, the reaction is not very quick.
Otherwise, try proprietary alkaline stripper from Enthone, Coventya, Atotech ... which are expensive but efficient and they don't eat polished brass.
Good luck
- Bordeaux, France
A. Use 250 ml/l hydrochloric acid anodically. The cathode can be carbon or copper. Add polyethylene glycol or glycerol to the bath. It has polishing effect. Add small amount of stannous sulfate. It coats on brass surface as a white coating to prevent further attack of the basis metal.
Lee Leongtee- Malacca, Malaysia
August 28, 2013
A. I would think the proprietary Ni strippers based on MNBS in 5% sulfuric acid with S activators would do the job.
Geoffrey Whitelaw
October 11, 2013
Q. Hello, can help me with this question. I have a brass decorative hardware (Ferrule on a table leg) with a nickel plated (silver) finish and I'm being ask to remove (wash off) the nickel plate and reapply a brass plated finish.
Is it possible to remove the nickel plate without damaging the integrity of the brass underneath and then reapply another plated finish?
I am not sure even if you need to plate brass over a brass core material?
Scott
- Lincolnton, North Carolina USA
May 11, 2016
A. Hi Scott. It is possible to remove the nickel plating from brass with proprietary strippers (see banner ad near the bottom of the page) or with generic chemicals -- but doing this safely and successfully may not be within the capability of the average inexperienced person (it's usually considered an industrial process). We don't know what facilities and expertise are available to you, and suggest that if you are not a professional plater, you might consider finding a plating jobshop to do this for you.
After removing the nickel plating you can probably buff the brass to an acceptable brightness and then lacquer it.
May 2016
