Need help cleaning/polishing aluminum cookware
I've read several of the editorials regarding aluminum refinishing/polishing, but I don't see anything regarding aluminum cookware. I have been given and purchased several pieces of aluminum cookware. Some of my pieces have pitting and utensil scratches inside of them. Others have years of baked/cooked on grease and goo on the outside. Still others are just dark from who knows what. I'm trying to find the best way to clean and possibly refinish (or remove the majority of the scratching and pitting) on the inside of my pots. I would also like to find the best way to clean the grease and goo from the outside and restore them to there former shiny finish. The outside of my pots are what some people call hammered aluminum finish. I'm not sure how to best describe the outside but it looks like indentions on the surface. I've tried scrubbing with a brass bristle brush and 00 steel wool this on eBay or Amazon [affil links] . It doesn't remove any of the pitting and scratching on the inside and very little of the goo and grease on the outside. The indentions seem to fill up with the grease and goo. Any suggestions would be greatly appreciated.
Thanks in advance,
Heather Hammock
hobbyist - Allons, Tennessee
Citric Acid
(in bulk)
citric_acid
A. 5% citric acid this on eBay or Amazon [affil links] solution?
Marc Banks
Elizabeth City, North Carolina
A. To clean the inside of the pans you could try soaking it with a mixture of Cream of Tartar and water. It won't remove the scratches and pitting but it should remove any discoloring. As for the outside of it you could try a industrial strength orange cleaner. These usually remove grease build ups with a little bit of old fashion elbow grease.
Tera Sandon
- Mankato, Minnesota
Q. How about Cream of Tartar to clean old hammered aluminum cooking pieces? I see this mentioned now and then in various places. Thanks, Ann
Ann Hollander
- Frederick, Maryland
July 4, 2010
Cream of Tartar
cream_of_tartar
thumbs up sign Thank you for the advice.
After putting a Kenwood mixer's aluminium 'K' beater in the dishwasher, it came out black. Just handling it turned my fingers black.
I tried washing and scouring it but just made my hands, the scourer and the washing-up bowl black.
Researched online, found this site, and then tried scrubbing it with a nylon scourer in a Cream of Tartar solution. It worked a treat and it has come up all shiny! Excellent!
(My wife reckons that pot of Cream of Tartar had been in the cupboard since at least 1999!)
Simon Reed
- Warrington, Cheshire, UK
June 14, 2011
Q. I recently acquired a cast aluminum juice king from an estate sale. It's beautiful, but I put the cup in the dishwasher and it came out with a grey film that I can't seem to scrub off. Any advice on how to clean it so I can use it again?
Rachel Gustafson
vintage kitchenwear lover - Bloomington, Minnesota USA
June 16, 2011
A. Hi, Rachel.
Never put aluminum in a dishwasher. Most dishwasher detergents ere extremely alkaline and readily pit and discolor aluminum. Please try the cream of tartar suggestion above. Good luck.
June 16, 2011
thumbs up signThank you Ted! My sister in law boiled some t-shirts in my aluminum stock pot. It was a wedding present my grandmother received when she married in 1925, and the only thing I have of hers. She put homemade lye soap in the water, and my pot turned BLACK inside. I thought it was ruined. I boiled it with vinegar in bulk on eBay or Amazon [affil links] and scrubbed it with SOS pad this on eBay or Amazon [affil links] . It looks like new, and I'm not threatening to remove her from the family any more! Thanks again.
Vickie Gower
- bethlehem north carolina
January 5, 2011
Hi, Vickie. Thanks for the happy news, and for the feedback. I feel better about what we post here when people come back and tell us what happened when they tried it. Readers may wish to see letter 22551 for more info about the boiling with vinegar approach.
January 5, 2011
Q. I have purchased some cookware on eBay but it is dull and shiny. Is there some type of cleaner to make it shiny again or some "do at home" remedy that I can use?
Sandra Morris
- Kenner, Louisiana
Q. Several years ago I was given three very old hammered aluminum bowls, which, at that time, I needed to used for baking. I have just finished soaking them and cleaning them in a dish soap solution with about 2 tablespoons of bleach bleach/sodium hypochlorite in bulk on eBay or Amazon [affil links] added. It has completely removed the grease that was baked on, but now the bowls are darker where the grease was. Is there a way to remove the darkening and then to polish them up a bit?
After reading the other responses on this question, I am now going to try a baking soda [in bulk on eBay or Amazon [affil links] paste, but I'm not completely optimistic!
Thanks so much.
Jean Henderson
- Willimantic, Connecticut
A. Look into the citric acid solution, Jean. I think the baking soda is unlikely to help.
Bleach is very highly alkaline (to keep the chlorine in solution), and as a result it rapidly dissolves aluminum. This leaves a disproportionately high concentration of copper or the other alloying materials from the aluminum alloy on the surface, and that's the cause of the black color. Baking soda will not dissolve this copper, but citric acid may (even though citric acid is not usually recommended for cleaning aluminum).
thumbs up signThank you so much, Ted Mooney! The citric acid worked great on my caked on popcorn grease. I make popcorn in my aluminum pot on the stove and the grease was stubborn.
I reached under the sink and used my Veggie Wash which is organic citric acid that I use to was my fruits and vegetables. Thanks, again, for your advice. It worked.
Judy Serafano
- St. Clair Shores, Michigan
September 26, 2009
Q. My guardian service was left outside and suffered the consequences. Please help! What is the safest way to remove the rust?
Brenda J. Alban
Consumer - Parkville, Maryland
A. Hi, Brenda. Only ferrous cookware (cast iron and stainless steel) can actually "rust" because rust is the corrosion product of iron. Is this cookware aluminum that is corroded in some similar fashion (pits, white spots, black stains)? There's some good advice on this page for restoring aluminum cookware. But maybe it is cast iron or stainless steel? That would probably benefit from a different approach. Thanks.
Q. I collect antique hammered aluminum serving pieces at flea markets and would like to know how to clean them. Thank you.
Judy Becker
- Seeley California
A. I've found great results cleaning my mother's 1940 set of aluminum cookware. Her set was entirely black on the outside from daily use for 60 years. I put the pieces in my self cleaning oven and cut in on the three hour cycle. They come out perfectly clean, but a little ashy. I then wash them and season them with oil much like cast iron. I also will leave my pizza stone in the self clean cycle when I want it to look brand new. We also solved the warped bottoms of my mom's cookware by putting the pieces on hot coals of a campfire, heating the pots and them covering the bottoms with a board and hammering with a sledge hammer....each pot is now perfectly flat and can be used on a glass stove top.
Marsha Johnson
- Kill Devil Hills, North Carolina
March 9, 2010
!! Hi All, This is just a kind Warning for the pizza brick in the oven post. I left mine in accidentally. The oils rise up and because the oven on self cleaning gets so hot it ignited a flame and set the oven on fire. It was locked and I could not open it. The oven and the Mircro hood were screaming with alarms and billowing with smoke. Just in case this ever happens. The firefighters immediately unplugged the appliances. (Wasn't thinking, shuffling the kids out.)
Kathleen Lewis
- Palmdale, California, USA
April 26, 2014
A. I clean pots, pans and roasters all the time. I love to go the thrift stores and eBay to buy these items. It appears that I buy the greasiest, most burnt up, baked on gooked up cookware there is. However, it is a joy for me to see just how clean and beautiful these items are once cleaned.
I found a round Guardian Roaster in a thrift store and, get this, for $10.00 with $5.00 off. I was elated. The roaster was as I described above except for the "most burnt up" part. I was afraid to clean it as I normally clean my other cookware such as stainless steel and enamel. So; I tried to clean it with just an SOS pad this on eBay or Amazon [affil links] since I didn't have any aluminum cleaner. Of course, this had some effect but not much.
Easy-Off
easy_off
I decided I would clean it using Easy Off. Although, on the Easy Off can it doesn't mention aluminum as being one of the products to use it on. I sprayed the Easy Off on the roaster and just let it stay on long enough for me to see the Easy Off turn brown from the grease and gook. Then I used one of those sponges with the scouring pad and scrubbed it all over. Once I got it cleaned with the Easy Off, I used an SOS pad this on eBay or Amazon [affil links] to scrub the roaster again. You can't imagine how clean and beautiful this item came. Easy Off is not usually used on aluminum. But I have also used it on aluminum skillet and then scrubbed them with a SOS pad.
You can also use comet and if the aluminum has turned dark from the Easy Off the SOS pads, Brillo Pads, and Comet will shine it right up. Try it, I promise you that you won't be disappointed. I certainly don't think so, if fact I know you won't.
Joyce Branch
- Naperville, Illinois, USA
May 13, 2010
Thanks for the highly detailed help, Joyce!
But readers: please don't extrapolate. While Easy-off cleaned Joyce's heavy cast aluminum cookware to her satisfaction when used judiciously, it's strong stuff that can quite quickly destroy thinner aluminum, or the finish on polished aluminum.
Ted, that is why I said let it stay on just long enough to see the brown gook start to dissolve (which is immediately). The only difference I see in my pan is the cleanness. Easy Off didn't harm my pan and it is part of the Guardian collection.
Joyce
Joyce Branch
thumbs up signHi, Joyce. I wasn't arguing with your advice. There's so much stuff on the internet that I often just quickly then run with something ... and I just wanted to warn other hasty readers to pay careful attention to the details that you offered them. Thanks again.
Q. Does cleaning my Aluminum ware in a self cleaning oven really clean the outside of my items? How detrimental is it to my Guardian ware? ALSO I have bought a lid to one of the tri-pots but has a film inside the lid that doesn't seem to want to clean off, it is sort of a opaque could someone give me a clues as to how to clean it ? Can the glass lids go in the dishwasher?
Sharon Brooks
- Bristol, Connecticut USA
March 25, 2011
I just literally stumbled across some of my fiance's grandmother's aluminum cookware in a box in the basement (we live in her old house). The basement flooded at one point and the cookware has this crumbly, white stuff all over it (I assume from the well water drying on it?). When I scrub it with an SOS pad and mild dish washing soap the white stuff is replaced with dark stains. It's very hard to get all the roughness off. Is there anything I can do to clean it all the way? There is a beautiful roaster with an aluminum lid I would love to use!!
Bridget Berry
- Crownsville, Maryland
October 24, 2011
A. I severely burned spaghetti sauce with meat into my vintage cast aluminum dutch oven. This 45 year old pot is one of my favorites. Just before throwing it out, I put a dishwasher soap tablet in it and boiled it gently on the stove. All of the burned sauce and meat came off.
Nancy McGinty
- Ellijay, Georgia, USA
July 1, 2012
Hi Nancy.
Glad that it worked, but I personally wouldn't use a dishwasher tablet on aluminum. Some of them are highly alkaline and will attack aluminum as well as the burned sauce.
July 2, 2012
Q. Hi, My son went to turn on my electric fryer without checking to see if there was any oil in it for frying. Consequently, it completely burned the bottom of the fryer which is aluminum. I tried a baking soda paste and scrubbed with 00 steel wool this on eBay or Amazon [affil links] with no result. Any suggestions?
Sonya Balling
- Kaysville, Utah USA
September 4, 2012
Q. So I cleaned my pot with oven cleaner this on eBay or Amazon [affil links] and now it has a ruined finish inside and out What do I do now. I don't care if it is ugly just as long as it is safe to cook in.
I had bought it at a garage sale and it was completely black with built up crude for about 30 years. Any chance to salvage it?
Carolyn Tilley
- Mandeville, Louisiana, USA
November 30, 2012
A. Hi Carolyn.
As long as the oven cleaner has been completely washed away, it sounds safe to me.
November 30, 2012
A. If you cook tomatoes or rhubarb in the blackened aluminum pans/pots they will be shiny once again.
Jean Hodges
- San Antonio, Texas
December 18, 2012
(you are on the 1st page)       Next page >
