How to remove old silverplate from copper?
How can I remove the silverplate from an old tray that is silver on copper? My goal is to have a copper tray. Thanks for info.
Doug Smarthomeowner - Roswell, GA, USA
You should send this to a plating shop for possible stripping of the silver followed by heavy copper plating. There is no assurance that you will have a useable copper layer under the silver, Doug. Copper is soft so I doubt that the tray is copper; it is probably brass with copper plated onto it for the purposes of smoothness after buffing. There may or may not be a smooth and heavy continuous copper surface under the silver and it would be a disappointment to work to remove the silver, only to find something ugly and unuseable.
