Tarnish-resistant Nickel plating substitute? Armoloy TDC?
Q. I need to know something about "Armalloy tdc" process.
PIERO D [surname deleted for privacy by Editor]EN plating shop - MILAN, ITALY
A. Hi, Piero. I can tell you that "TDC" is an acronym for "Thin Dense Chrome", and that the correct spelling of the brand is Armoloy®. It's a proprietary name/type for chrome electroplating. Hopefully this is enough that you'll be able to further research it. Good luck.
Q. For years our engineering department has chosen nickel-plating as the corrosion resistance method for all carbon steel products we manufacture. The two biggest problems we have experienced are 1.) threads cut under/over size to allow for plating have not been gauging and 2.) a tarnish or corrosion has been reported to have developed (especially in some foreign locations) on the nickel.
We have been looking for a suitable substitute to nickel-plating since we no longer can use cadmium or zinc plating. Armoloy is what we have been experimenting with on some parts. Any ideas?
Stephen DonaldsonAerospace Industry - Houston, Texas
A. Armoloy (which is simply fairly thin hard chrome plating) may work well. It should not tarnish as nickel does. Corrosion resistance could be a problem. It depends on the environment. Electroless nickel might be a good choice too.
A. Hi Stephen. Electroless nickel plating is consistent in thickness and would solve the gauging problem, but it is much more expensive than electrolytic nickel plating.
It is understandable that you can no longer do cadmium plating because it is a bio-accumulative poison which everyone is trying to remove from the environment, but you haven't said why you can't do zinc or zinc alloy plating -- and it is important to challenge assumptions to get the best answers. Remember that only cadmium, zinc, and aluminum plating offer galvanic corrosion protection, and aluminum plating is very expensive. Other platings are more noble than steel and are "barrier layer" rather than "sacrificial"; if they are porous due to thinness, or become scratched, they accelerate corrosion and can be worse than no plating at all :-)
