Need help with scratches on matte finish 10K ring
I have a 10K white gold ring. It is polished on the ends but matte finish in the middle. The matte finish is all scratched up and I've had it only 4 months! Is there a way to polish the matte finish back? Any suggestions?
Kevin Methvin
- Pleasanton, California
A matte finish is what I like to refer to as a "soft" finish, not too terribly reflective. Most matte finishes are done by bead/sand blasting (at least on my work). You have a few choices, one get someone to sandblast the part of your ring you want to have that matte finish then get it rhodium plated (will keep the scratches away a bit and keep the bright bits bright). Or you can have a jeweler polish the matte part to a high shine. Either way I do suggest getting the ring plated to protect it.
Marc Banks
- Elizabeth City, North Carolina
