Heat Resistant Paint
I an looking for a standard heat reistant paint which can be applied on a thin aluminum plate used for equipment tagging. Please kindly suggest the maufacturer's product code with details.
SIVARAJ KARPURAMConstruction Development Company - DOHA, QATAR
VHT makes spray paints that are heat resistant, I don't know product codes. If you go into any auto supply store they usually have some type of engine paint or header coating that'll do what you want.
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
I am looking for a heat restant paint which can be apply on a croam plated plate,this will work on steam on 200degree temperature.so kindly suggest me.
PRECISION RUBBER INDUSTRIES P.LTD. - Indore(M.P.), India
